Last week I mentioned on a thread that I would like to try out new low-noise ICs, and TI were kind enough to send me some samples of their INA163 as being the latest and best?. (I notice that it was actually introduced in November 2000)
I did say that I would report back:??..
Tested strictly in accordance with the spec sheet, it?s certainly very quiet; the ?self noise? was so low that it was almost within the tolerance of my test equipment; measured against my 200 ohm precision resistor, it was certainly within a dB of the physical limit (I was measuring 129dB below input at 50dB gain, 20Hx ? 20KHz RMS.) [My rig could be up to 0.5dB optimistic].
Reconfiguring it as a balanced mixing stage, it did not work at all well; I suspect that the ?block diagram? is very much that? it really doesn?t work trying to use the internal op-amps in a different configuration? so that?s that idea out the window.
Rigging it up as a mic amp, as a comparison with some of my own experimental mic amps, I found that it is horribly sensitive to cable capacitances, and there?s a very good reason that they publish a ?stabilisation network? for the input ?when used with low source impedances?; I only wanted to listen to a ribbon mic! :shock:
Once it was stable, it sounds fine and not significantly different from my ?standard? amp, which is a transformer input balanced class-A design; which, incidentally measures 2dB worse on noise, but sounds about the same.
I had a look at the distortion products on the analyser, which was difficult, because at 50dB gain there?s really not much to see. I couldn?t find any 2nd order, and only the merest hint of 3rd.
While it was an interesting exercise, I?m still looking out for op-amp types that work optimally (as far as noise goes particularly) as current amplifiers.
Ted Fletcher
www.tfpro.com
Ted Fletcher
www.tfpro.com
