matta
A while ago I started working on DOA Telefunken V672 module and Mark Burnley, amongst others, came to my troubleshooting rescue. He suggested I trace the signal path and I was pointed to his DIY signal probe (http://www.diyfactory.com/data/mbsignaltracing.htm). Long story short I never built the probe as I found the problem to be a bad lytic cap without it. But it did make me realize at some point I need to make this probe.
I've had it in the back of my mind for a while and started thinking how I could adapt it and have a self contained test kit, and after brainstorming with a friend (Lourens Steyn) who has a lot more insight into schemo's, and breadboarding (read, I have little to none) we came up with a box of tricks.
I found a headphone amp schemo on the web and build one side of it connected to a 2 ½ inch 1W speaker, driven by a trusty old NE3354, we also built in a simple tone generator, with some resistors we had lying around, so it gives me around a 4K tone at Mic Level, 0db (-10) and 0db (+4).
It also has a nifty RED LED with a Zener on the probe so if I hit anything over +11V DC it lights up to warn me, not that is needed the speaker tells you as well ;-)
Excuse the pics, they were taken on my phone. I'll post better pics later, as well as the schemo and give credit to the sites we took ideas from. Our first design had to be adapted on breadboard so this box differs from the original design.
It might not seem like anything new, but it was for me, as it was my first attempt and 'designing' something and using veroboard (perf) to make this funky box...
So in honor of Mr Burnley I called it 'The Burnalizer'
Matt
Matt
