cantgetnosleep
Well, I finally returned from working abroad and I've gotten to start actually making stuff, instead of just reading the forum while procrastinating at work. Now this means I'm having problems, however.
I decided to build a simple power supply for experiments cloned off of the GSSL powersupply (mainly because I had parts and the schematic). The 15V rails seem to work reasonably fine. I'm getting +14.8 and -14.7. It's the 12V rails that are giving me issues.
I'm using an amveco toroidal transformer to step down the 115V. I read 19VAC off of the transformer.
After the bridge rectifier, I'm getting about 26VDC and a few volts AC on my meter. This seems a little high and I believe (if I read the spec sheets right) is just at the top range of the 79L12 and 78L12's tolerances.
I checked the circuit on the scope, and the seem to be doing a good job of smoothing out the DC. I also noticed that the 79L12 and 78L12's were getting very hot. The +12V rail was reading 800mV and the -12V rail gave me 26V, or just a little less than the input.
I did try switching the regulators out and I got exactly the same result on both rails. Hmmm.
Any help would be greatly appreciated!
Thanks - Andrew
btw - has anyone noticed that the seem to have tried to make the pin assignments for these things as confusing as possible. Not only do they change the pin numbers for each leg between these, but they also change the functional designation of each pin number. Arghh.
Thanks - Andrew
