OK, the original post is now recovered, though I am under the name "guest". Ethan - fine work! The most important thing is that the continuity of the threads isn't broken with missing posts. :thumb:
Time to comment.
The diode clipper is really just the tape compression circuit posted here earlier. A HF pre-emphasis followed by diodes and a de-emphasis. The only things different are that the op-amps are on single rail, the filter is slightly tweaked and I have two switchable sets of diodes there. Germanium and silicon. Hash & Crack. :grin: They can be out of the circuit, too.
That thing has tons of gain and when wanted, it can be clipped in various places actually. :shock: Or used as you basic 1176. With stereo link.
Coolest thing is the high pass filter. This one really need it!
I got a great idea from this project I'm working on!
If you're aware of parallel compression (adding compressed signal to non-compressed), the 1176 is the most perfect compressor for the job. Fast attack and a good range in release.
I'm doing a thingy where the original signal is multed, converted to M/S, taken to the pre-amp section of the 1176, back to L/R with some gain (and an output pot) and then mixed with original signal.
