dale116dot7
There was a thread about the Distressor dissection.
The 20 pin IC's are something like 74HC573's used to keep the counter values during a power down. They are powered from the super cap.
The analog part of it is basically an 1176 - but replace everything with op-amps.
Distortion generation is by unbalancing the drain channel modulation compensation circuit (The part that feeds audio to the gate along with the control voltage).
There are diodes in there that look like they are clippers for distortion generation - don't get fooled. They are not there for that purpose - they clip the input signal only on an OPEN digital switch to prevent digital MUX feedthrough (when the signal exceeds VDD or VEE on those IC's the appropriate switch turns ON). This fooled me for a few minutes till I watched the signals with the scope.
There is no digital anything in the feedback circuit, and no software to be found. The muxes make it easy to patch things for different sounds, ratios, etc, but they are just that.
I can post a hand-drawn rough schematic (up for correction) on Monday when I get to work (I don't have a scanner at home). I don't think I'll reverse engineer the digital part as it's just a few counters.
