Mendelt
I just read an article in elector(don't laugh, i got a stack of them from a friend) where they claimed that even film capacitors will work differently depending on how you place them in acircuit. Especially in high impedance circuits.
Their reasoning was that because film capacitors are rolled up stacks of film. One side will be connected to the outside-film and form some kind of shield. So if you use a capacitor to ground, it will be better to connect the outer film to ground to reduce rf interference and stuff like that. They even had a circuit to find out what leg the outer film was connected to.
Is this effect noticable in audio applications? Do the ceramic capacitors most people use to decouple op-amps also have this 'feature'?
