I did not see this post when i inquired about this..
But here is some additional info:
Quote:
Hello..
Wiring up my G1176 and I am not quite sure where wire # 1*is supposed to go? I am using a luhndal input transfo.
It is the hole labeled #1 and it has a *
It appears that people wire things a bit differently by looking at others pictures that have been posted.
Quote:
With the optional traffo input, connect to the 1* ( the * are used if you have the traffo there, like the resistors and caps up in that section).
Quote:
Thanks FUM,
Question:
So.. pin #1 from the input potentiometer which would normally go to
hole #1 (input gain) goes to hole labeled #1* instead if I follow you correctly. So pin # 1 (input gain) will be left empty?
Quote:
Yes, the 'PIN 1' spot is left unconnected. The NE5532 input stage will not be used - its output goes nowhere if you put in those parts - you can eliminate the NE5532 and all of its support components
