Hello all.
I have built a couple mic preamps, and they are doing the job just fine, but I would like to reduce the parts count and cost of input and output transformers. Inspired by the NYD one-bottle preamp, and the cost/quality of the edcor transformers, I came up with this design idea:
- a 6sn7 configured as conventional RC coupled 2 stage amplifier, with volume control between the sections.
- input transformer: Edcor RMX-1
http://www.edcorusa.com/classx/ribbon/rmx/rmx1.htm
- output transformer: Edcor XSM10K/150 configured as traditional series-feed output transformer, like in the RCA bc-2b. Not parallel feed.
http://www.edcorusa.com/classx/matching/xsm/XSM10k-150.htm
- simple unregulated power supply with shunt regulated zener diode phantom power supply.
- extra shielding for transformers via hammond die cast boxes, or folded-up copper boxes or something.
- no feedback.
- gain configurable by choice of output transformer, and use of cathode bypass caps or not (switchable even). And as with most tuube circuits, building a deluxe power supply will probably improve the sound. Maybe a deluxe power supply in a seperate chassis, and a multi-channel mic pre chassis.
This should be a very simple, very inexpensive project. And the components should take up very little chassis real-estate so a multichannel chassis should be possible.
Upgraded transformers are available from Lundahl, etc.
What do you guys think? I'll draw and scan a schematic if anyone is interested.
What do you guys think? Has anyone used the Edcor RMX-1 as a mic input transformer? It looks awesome, but I wonder what the maximum signal level is. And how do you mount these things? Could it maybe be potted in some sort of Hammond box or mu metal can or something?
jsn
- no feedback.
jsn
