Hey guys,
Having thrown some ideas out there for a simple tubed mic preamp, I have changed my mind a bit. In my concurrent seach for a phono stage to build, I ran across the Aikido amplifier circuit at tubecad.com. It looks ideal for a mic preamp.
Basically the Aikido does 3 cool things - it injects the inverse of the power supply noise into the cathode follower to cancel power supply noise, and it loads both the gain stage and the cathode follower with the same tube, which has a neat distortion cancelling effect. As a bonus, you can use many different tubes in it without any changes to the circuit.
Here is the Aikido info:
http://tubecad.com/2004/blog0011.htm
http://tubecad.com/2004/blog0013.htm
http://tubecad.com/2004/blog0016.htm#MoreAikido
http://tubecad.com/2005/January/blog0030.htm
http://tubecad.com/2005/January/blog0032.htm
http://tubecad.com/2005/July/blog0051.htm
Of course you can just go to tubecad.com and read all about it.
I would like to adapt this to a mic preamp using an input and output tranformer for balanced operation, and around 40dB of gain with only 1 gain stage and a cathode follower. Of course using the Aikido topology you need 2 tubes for this so the whole one-bottle thing is out.
Here is the schematic I have in mind:
I figure with Altec 15095 input and output transformers, and a 6sl7 for gain and a 6sn7 got the cathode follower, I should get about 36dB gain, minus various losses. To get less gain, you could use a 6sn7 for the gain tube. For more gain, you could use an Altec 4722 as the input transformer , or an Altec 15335 10k:10k as the output transformer, or both.
And if you used 9 pin tubes, you could play with *tons* of different tubes for various levels of gain and to play with the sound of all the available 9 pin tubes.
What do you guys think about the volume pot right off the input transformer? Is there a better way to do it?
I also plan on adding a -20dB pad, a phase switch, and phantom power.
I have this thing started, and will post more info as things progress. I have been trying to perfect an eyelet circuit board and ground bus construction technique, that I hope will be neat and quiet.
jsn
jsn
