mikep
Ive been thinking about trying to combine a VCA compressor with a parametric EQ circuit. not a multiband compressor, rather a dynamic EQ. there is a plugin I really like that does this, the sonalksis DQ-1. I like it for de-essing and also for low freq upward expansion. Has anyone done this already? Im thinking the best candidate for the EQ would be the s+o#n*tec/G*M&L circuit. ideally you would have flat response with no GR then as compression increases the filter gain gradually becomes whatever the boost/cut pot is set at. this is roughly acheivable by putting a VCA+inverter in parallel with the signal coming back to the summing node (the signal that goes thru the vactrol in an M.E.P.2.5.0). Im thinking an FMR RNC would make an ok comp for this purpose. any ideas?
mike
mike
