Hi Michael,
Welcome, and thanks for expressing interest. The tubecad website is great. I refer to it alot, especially
the Grounded Cathod Amplifier article
Edit: I totally miscalculated the gain somehow.
I gotta give credit to PRR for the inspiration and starting point:
[quote author="PRR"]let's see.... 300V supply, 10K DC resistor, 20mA, puts 100V on the plate. We can cleanly swing a low-Z load to 10mA and 30mA, 10mA peak. With a 2:1 transformer, 2K4 primary, we can swing 24V peak primary. We have 12Vpk 20mA peak at the secondary, +21dBm in 600 ohms. The incremental plate resistance here is about 1K, so damping factor is 2.4, so output impedance is 250 ohms, resonably low. It looks like about 14Vp-p on the grid, and 7Vpk in for 24Vpk out is a gain of 3.4, which agrees with Mu about 5 and this ratio of Rl/Rp. Gain to the load is 2:1 less or 1.7. The small-side of 6EM7 can easily give voltage gain of 40 (use 12AT7 tables). Total gain from first grid to 600 ohm load is 70, or 37dB. 1:10 input iron makes it 57dB. That may be too much for some uses, put a pot between stages. How far down can we turn the pot before the input tube clips first? Taking voltage-amp peak output as 20% of supply, the small-side can make almost 60V peak, we can turn-down 18dB. After that, the input stage clips before the output stage reaches +21dBm.
Working the tube richer, with the plate around 60V, buys a little lower Rp and a little more gain. But we may have trouble holding it there. 80V-100V on the plate may be more stable.
You could also work things at lower B+. Some TV sets worked as low as 110V B+. But this works much better with transformer-coupled (DC in the iron) than RC-coupled (iron just for matching).
Working 300V B+, 4K resistor, 50mA current, 2k4 load, we could pull 50V 20mA peak, 25V 40mA peak in the load, +27dBm. Gain rises to 4, Rp drops to 800 ohms. If we don't need +28dBm, the small improvement is probably not worth the added supply power. Note also how little the performance changes when plate resistor and current changes by a factor of 2: we do NOT need precision parts to get consistent results. 4/3.4=1.4dB. Your idiot parts-assistant got 7K4 instead of 4K7 resistors? Slap 'em and ship 'em... customers will never know.[/quote]
