ioaudio
this is about a tube mic pre with a triode/pentode switchable ef86 input and a srpp output stage using the ecc82.
uploaded the pictures from the prototype again
inside the prototype:
schematics:
the gain switch "includes" the -20 pad, using a 4x3 pole switch.
psu:
bear in mind that the lm317 has plenty of work burning about 7 volts. thats ok for one channel, for a dual preamp i would suggest to adapt the heaters for 12 volt ( 2x ef86 in series, ecc82 work with both 6,3 or 12 volts)
schematics:
psu:
