radiance
Most Subwoofers I came across have a build in cross over. You send your monitor signal into the sub and the (high pass) filtered signal for your speakers comes out the output of the sub.
What I wanted was a way to switch between "only speaker", "speaker + subwoofer", "only subwoofer" and last but not least "off".
The router I build can be done with three 2 pole relays (dpdt) or with a 3 pole 4 position 4 deck rotary switch (a 4 pole 3 position 4 deck wil do but than you dont have the "off" position).
