I must admit in all my building of Neve preamps, I've never actually built the proper line input as used in the 1073, etc... I'm actually about to do just this to upgrade a pair of mic input-only modules that I currently have, so this is just the exercise I need to get ready.
I looked over the 1073 drawing and have a couple of comments regarding yours:
1) The line input position of the "Mic/Line" switch should have no connection whatsoever to pin T on the card (right now it is connected to what looks like the pole of the line switch (at the bottom in the drawing). Lose this connection.
2) the top of the line switch in the drawing (at 'R24', the 27 ohm resistor) should be the only pole of this switch. A 1x12 Lorlin switch, shorting (also referred to as 'MBB', Make Before Break), would be perfect for the line input gain (assuming you're using separate mic and line gain switches as the drawing shows). This switch can be set for only 8 positions. Perfect for this application.
3) You have connected R7 (430 ohms) at the bottom of the line switch to audio ground, which should not happen. Instead, the connection to audio ground should be made at the point where R19 (220 ohms) R9 (33 ohms) and R1 (2k2) connect. By connecting R7 to ground, as you currently have drawn, you completely short the signal from the line input transformer directly to ground = no output. The ground connection should be on the OTHER SIDE of R1 (2k2) for the circuit to function properly. If I were building this drawing I would simply connect the junction of R19, R9 and R1 to the audio ground of the mic gain switch (assuming the switches will be side-by-side on your front panel) and then just use one lead to connect both gain switches to audio ground on the card.
4) The shields you've drawn (I believe that's what the big black dots that connect to the audio ground are, anyway) are connected to pin V at the bottom of the line input transformer on your drawing. I realize the shield for this transformer's primaries are connected to pin V, but on an actual Neve module, pin V is the chassis connection (look at the mic input transformer on a 1073 drawing, and you will see the core of the transformer is connected to the chassis AND pin V). I realize you are not working with an actual Neve module here, so this chassis connection is not established, but I just thought this might be worth mentioning assuming you also refer to Neve drawings and wind up connecting the transformer cores to this as well, in which case you will wind up with considerable noise issues, particularly at higher gains.
This is something you absolutely must watch out for when building Neve stuff. Using the chassis for a shield connection is fine, so long as the other end of that shield doesn't connect to the audio ground ("B-" on Neve schematics). They shielded the input of the line transformer and the outputs of the output transformers to chassis (again, looking at the 1073 schematic), but notice that there is no connection of these shields to B-/audio ground anywhere in the module. In Neve consoles the connection of audio ground/B- to chassis ground/Earth was only made at the power supply.
5) remember to shield the send from pin P to the 5k audio taper pot as well as the send from the pot's wiper to pin L.
6) I know it's just the way your drawing makes it look, but just to be sure, the mic input connection to pins U/S on the card should be from the first pole of the mic gain switch. Right now it looks as if it is connected to that pole's shield. Like I say, I'm sure it is just the drawing, but make sure it is connected to the pole, and be sure also that this lead IS shielded to ground somewhere. This is a very low-level signal, so the shield is critical here.
I think that should just about do it for you. Please let us know how it turns out.
:thumb:
JC
Edit - oh yeah, as for clicks, I don't think you will experience anything significant when switching from mic to line inputs and back. Remember to use 'shorting' (MBB) switches for your two gain controls.
Also, I just realized that you don't need the "OFF" position on the line input. This was to avoid pops, I believe, when switching from mic to line inputs on a single, shorting, gain switch like Neve used in their channel amps. You are doing this by way of a separate mic/line switch (most likely non-shorting), so this isn't necessary. You can leave this position out and go with just the 7 line input gain positions.
