> features no phase inversion
It's got two transformers; what does it matter if the amp inverts? Swap a winding.
> high gain
1:2 input iron. 1:30 in the tube. 4:1 output iron. Gain is 15, or 23.5dB. That's assuming a zero-Z source; with typical dynamic the gain drops to 17.5dB. Take a dB or so for transformer loss, 16dB. High gain?
> low input resistance
Looks like 150 ohms.
> A minimal amount of feedback
There is no feedback in the audio band.
What you do have is some damping of the output transformer/cap resonance. A hasty calc says 68 ohms might even be "critically damped" for a transformer similar to this. And gain times 68 gives a passive output resistance that would do the same job. Better: this feedback is "exaggerating" the transformer saturation, something you could do (if you wanted) by using a smaller cheaper core.
> disproved much of what I hear about noise
I'm not interested in "noise" of a 22dB-16dB gain preamp. The input noise is around 0.5uV, the output noise near 5uV, the S/N re:+4dBV is 108dB, re:+20dBV is 124dB. In situations where ~20dB of gain is enough, noise is NOT an issue even if it is 10 times higher than theoretical.
> Great sound
I'm glad you like it, and that you can live with such a low-gain preamp. You must have hot mikes and sources.
