The purpose of that 'instrumentation' amp configuration is to:
- provide (usually) a high input impedance on both input legs
- provide best in class CMRR
- provide the necessary gain
- provide low noise and distortion.
The first 2 are particular features of that 3-amp layout, and the 3rd is readily acheived. As usual, the 4th is a matter for the specific implementation....
If anyone has a few JH990's lying around, then it might be worth a try to see what it sounds like
... IMHO, any high-quality amplifier (using the rather more conservative definition of high quality - ie, low noise, low distortion, no instabilities, flat frequency response to sensible limits, etc. etc.) will sound identical.
Where one amp has a different 'sound' to another one - one (or both) has some (usually very) measurable impairment (enhancement????) to the signal.
eg. You can readily measure the effect that transformers, inappropriate electrolytic caps etc., and poorly designed circuits (or at least, circuits designed with aims other than high fidelity) have on a signal. You may like what it does, you might not - but it is distortion...
<short_rant> You cannot, to my knowledge, yet measure how 'golden' someone's ears are, though </short_rant>
Alan
