> Is the second half of V1 grounded-grid?
The whole "Frankenstein" is a perfectly simple
differential amplifier (U1)
plus a fancy cathode follower (U2).
You "can" see U1 as a cathode follower driving a grounded grid stage.
That's not as useful as understanding it as a Differential Amplifer.
But if you must: what is the difference between a Grounded Grid with a
hard-grounded grid, or a GG with a <10K resistor in the grid return?
For audio: very little. The grid is ~200Meg||~30pFd, so 10K is "nothing".
> where's the gain?
Mostly in the 1:10 input transformer.
U1 will have roughly half the 12AT7 handbook gain, say 20-25.
U2 has gain over 0.9. Then 2.5:1= 0.4 in the output transformer.
10*25*0.4= 100 overall.
NFB reduces the V1 gain from 20-25 toward a target of 11,
so probably 5 to 7, around 25 overall.
The 1:10 transformer is necessary for lowest noise,
because we've "stacked" the noise of two cathodes.
Gm of 12AT7 at 1.2mA is about 1,500uMho. Rk= ~660. Rn= ~2K.
For gain and noise calculations, Gm is effectively between
U1a grid and U1b grid, so Gm= 750uMho, Rk=1,300, Rn= 4K.
The source noise resistance is 200 ohms times 1:10^2 or 20K.
4K tube noise added to 20K source noise is "small",
but with a 1:5 transformer it would be ~3dB NF.
> Small value resistor and low voltage is a no-no.
The signal will be attenuated and S/N ratio will suffer.
Oh, it would not be good but not so bad.
If U1a's Rk is 1.3K, and we use an 11K cathode resistor,
attenuation is like 0.9 or -1dB.
The voltage across the long-tail only has to be much-much greater than
Vp/Mu, where Vp is around 125V and Mu is around 60.
So we need much-much more than 2V. 25V is much-much more than 2V.
We also want the voltage on the long-tail to be
much-much more than the common mode input voltage.
Hmmmm... the max output is 20V peak.
At lowest gain, we need 8V peak at U1 grids.
And 25V is not much-much more than 8V.
Then a CCS or a deeper voltage is called for.
