sonicwarrior
In another forum (synthesizerforum.de in german only, sorry) I came up with the idea for a band bypass switch for each of the 4 bands.
Pros:
- No need for a center detent 10k linear pot
- The center detent is usually not 100%
Cons:
- An additional switch (on the frontpanel)
Another user there who has way more knowledge about electronics suggested to to this the following way:
Solder a switch in series (corrected from "parallel") to the 5k1 resistors at pin 2 of IC 6A/8A/10A/12A (Schematic).
As I'm an electronics newbie:
Do you think this works?
I've done a search here before and look at the META pages for the Calrec EQ but didn't found something like that.
Pros:
Cons:
