[quote author="kvintus"][quote author="jdbakker"]What are you planning to use this for ?[/quote]
Phantom power to a microphone :roll: .[/quote]
That bit was clear.
[quote author="kvintus"]I think he will use it for some portable measurement system or something like that.[/quote]
That's why I asked. Is there any way to extract power from that system ?
[quote author="kvintus"]An other idea! Three AAA batteries in series will give us 4,5 V and would probably fit inside the tube. That could be something, right?[/quote]
Yup. Either go with:
- a (7)555 and a simple diode-capacitor voltage doubler (simple but inefficient)
- a Linear Technology LT1073 or similar (available from Digi-Key). The LT1073 data shtte has several design examples, and it's available in SO-8 which is small enough to fit in the tube but large enough to DIY.
- a specialized microcontroller like the ATTiny26L, programmed as a step-up reg. The advantage is that, if you have access to the sampling clock, it is easy to synchronize the switching so that you get minimal noise.
If you can choose between several step-up regulators, pick one without burst mode; burst mode is good for current efficiency but bad for conducted and transmitted noise.
HTH,
JDB
[who is using an ATTiny as a phantom supply for a portable mic pre]
