I haven't tried different Fets or any other circuit changes in this LD mic yet.
Right now, I'm concentrating on the mechanics of the capsule mount. The handling noise rumble is, imo, currently way too excessive - so I'm hoping to come up with better suspension rubber than it currently has. I think a low cut filter is also going to be a really helpful for rumble. I'm thinking of something stepped - start with sub 20hz (17 seems a pop number) and then maybe with a 30hz cut - for proximty, if so desired. (I have to think about it and am open to all thoughts and opinions)
In terms of circuit tweaks - I applied some of the changes I made in this mic to a Tsb165 mic I built a couple days ago, and noticed improvements in the tsb165 circuit!
The changes - I dropped the 12v zener 'power' diode to 10v, and in the amplification area raised the typically 100k resistors (the ones at the transistors) to 150k.
What is interesting is that the mic is hotter now than before - with consequently lower noise floor. I'm going to try changing a couple older tsb165 mics over to this config to A. see if it was coincidental and B. if not - well - it would be a marked improvement.
I have been meaning to pose this to the group to see if anyone had an idea of why less voltage would result in a hotter mic?
