Samuel Groner
Hi
Recently I've seen many threads here with people struggling with the basic calculations of linear power supplies. That's a pity I'd say as linear power supply design is--at least for low-power DIY audio needs--a simple task, once you got your head around a few formulas.
As the calculations required are repetitive and boring I decided to publish the Excel spreadsheet I put together to speed up the design task: PSUCalculator.xls
Based on several input values (such as transformer secondary voltage, filter capacitor values, output current and output voltage) it will calculate important parameters such as regulation headroom, regulator dissipation and transformer power rating.
I hope the short documentation will be sufficient for successful use of this spreadsheet--otherwise feel free to ask here and I'll give more information.
Samuel
Samuel
