seavote
read the metas. still have 2 questions. ht and heater grounds should be connected to chasis ground at the 7 pin xlr in the mic housing as per gyraf and others. but ioaudio writes in a thread,"just connect the three grounds (HT, Heaters & signal) together at the 7-pin xlr from the microphone. should signal out ground also connect to chassis ground??
also i have 2 of gustavs pcbs with trace errors mentioned in this thread
http://www.groupdiy.com/index.php?topic=566&highlight=g7+hum
i jumped the gap so no problem there. my question is this. the ht ground and heater ground are connected on the pcb by this trace,are they not? therefor,couldnt i make one connection from one of their respective pads to chasis ground, as they are connected to each other already? if not can someone explain why . i like to simplify if i can . thanks
