dukasound
After long, long, time (over one year) G7 works :grin: .
I have problem with right voltage. I must exchange second transformer with 220V-15V (I cant get higher than 140V).
Now I use 220V-12V (in wrong way) and I had 180V and with zener and poly in parallel now I have 160V.
Voltages:
After 10K- 156V
On plate- 70V
Cathode- 1,39V
Capsule- 75V
Pattern works very good. When I assembled mike and push on I measure all voltage and I got sound but I
had only omni :shock:. What happened: I cant find new styroflex 10n and I used old one who was bad. I find another old one and problem was solved. Also I cant find 2,2uF for stabilize voltage and I use two 1uF. I have one 2,2uF but I cant put in chassis.
On first listening it sounds very good. Other mikes doesnt sounds better but different
Like on other two mikes I have hum (who is decrease to zero when I touch mike near capsule or when I put another one mesh over this. Now I used mesh about 16x16 on Ela M and 18x18 on C800D and G7.
Mesh is nickel steel. Soon pics.
Thanks to Ward, Thomas, Jonathan, Moby for parts and to my friend Vasco who help me with works on lathe. All other works is handmade.
Voltages:
After 10K- 156V
On plate- 70V
Cathode- 1,39V
Capsule- 75V
