renx
After numerous listening blind tests and A/B comparison of SSLTechs version of Jackobs GSSL, and the original mix bus compressor from the 4000 series console (manufactured in the 80's), made me come to a conclusion that the they sound different. Not only to my ears but to people who use this equipment on daily basis.
The main difference is that the GSSL is more open, more of the higher frequencies were observed, and the console compressor sounded "tighter", sort of gluing it a little better. Of course these are all subjective opinions!
I am sorry if I didn't explain this good enough, but putting sound into words has always been difficult for me.
Anyway, I started to search for an answer and after a lot of research I concluded that it must be the VCAs that make the difference in sound (I know that some people disagree with me). So I experimented for a long time, burning a couple of 2181s and I came up with a two designs using 4 and 8 21xx chips, like the THAT202R and THAT2002T which can be found in some x-logic units.
I found that the 8 x 2181 sounded almost identical as the original. This test was made by sending one signal to both, GSSL and the original unit, then inverting the signal which came from the GSSL and adding it to the non-inverted signal which was coming out of the original unit. The result was a silence which proved that sounds from each unit are almost identical!
Here is the pic of the vca...
sorry for the blurred picture but I had to make it in a hurry.
The vca is a bit large, I suppose it could have been made the same size as THAT2002T, but I didn't care.
Sound clips will be posted here as soon as I get the unit back from further testing.
Personally I like the Jackobs GSSL sound better.
Regards, Renx.
Regards, Renx.
