dagoose
Right now i'm in the middle of doing a passive insert box for my mastering with 6 inserts: 3x compressor and 3x EQ.
It will be quite simple (well.. thought it was simple when i started) with 3 stepped switches powering relais for the 3 inserts for the compressor side and also a 3 stepped switch for the EQ side.
To do that it has 24 relais for just the inserts in and out (that is balanced ofcourse).
Then it will also have a bypass for the compressor and EQ so that if i only need an EQ i bypass the compressor (10 relays in total).
Most of the times i use the compressor first and then the EQ but sometimes i want EQ and then compressor, to do the swithing with just one button you'll need an extra 8 relays that makes a total of 44 relays
I will post the schematics for that soon..
The thing is.. i also want to do parallel compression, so actually a wet /dry for the compressor inserts.
I was thinking of using a 4 deck 12 stepped swith with resistors like in the really simple schematic below. (only one channel and just +, in total you'll need this 4x)
Will this work and what values should i use for the resistors?
Or does it work a little different then i think and do i have to use some active summing?
Anyone?
Anyone?
