vertiges
Hi there,
I've been trying to understand this for weeks... :roll:
The Gyraf G7 Page
CAPSULE BIAS RESISTOR
1.1) Is the polarization voltage of the capsule determined only by the two 470k ?
1.2) As long as these two resistors have the same value, the polarization voltage will remain 80 volts, right ?
1.3) Why choosing 470k ? Do these resistors act as a filter in combination with other components ?
2) As I understand it, there is no DC current across this resistor, because there is no path to ground after this resistor. If there is no DC current, there is no voltage drop of "the 80 Volts". So the 80 volts are only a potential reference brought at the capsule and the 1GigaOhm has no effect on this voltage. Is that true ?
3) About AC current : as I understand the Jakob's explanation, this resistor "kills" the leaking currents(=discharges) from the capsule ? What would happen if the value of this resistor is decreased ? It would reduce the voltages variations applied to the grid ? And the microphone would have less output ?
I'm asking because for example the U47 has a 100 MOhm.
4) I've read it's not possible to make a voltage measurement with a "traditional" multimeter because of the high impedance of that part of the circuit. Is it still true if the measurement is done "before" the 1G ?
"The pattern" RESISTORS : 33M and 10k
1) What is the role of the 10k ? Does it make an low pass filter with the 100nF ? Is there AC current in this part of the circuit ?
2) What's the role of the 33MOhm ?
3) There is no DC voltage drop across this resistor, right ?
4) I can't measure this polarity voltage with a traditional multimeter, right ?
I'm sorry, it's a lot of questions... :wink:
Thank you,
eD)))
EDIT : I've changed the title of this topic as these questions apply to all tube microphones and not only the G7.
The Gyraf G7 Page
Thank you,
eD)))
