pucho812
It always amazes me how some companies will make you jump through hoops just so you get the replacement part through them at a inflated price or worse send in for a referb unit at a more inflated price.
Case in point my SSL 9000 fader issue. I have traced it down to the motors on the large faders going bad. It's not a servo card issue or anything of the sort. it's been random over the console. Sure enough the moment we replaced the motors from a spare fader with a known bad fader, the bad fader worked as per normal. Plus we have one fader where the shaft coming out of the motor snapped off. Definitely the motor on that particular one for sure.
SSL refuses to let any information about the faders out and says just send us the whole large fader assembly and for 500.00 dollars we will replace it with a new one. the total cost for our studio would be over 4000.00 dollars not a good option.
I called alps who were little help going if we have a part number we can get you those faders at a minimum order of 100 units. Then adds that BTW we can't sell you just the motors. More over when I gave them what little information I had with resistance and the batch number when they were made, they couldn't really help me.
I have been back and forth with both companies.
So after much research I have an ALPS motorized fader coming which when looking at the engineering drawings from alps looks like it will work. All we need is the motor so we will jack that from the free sample and see what happens.
Bottom line is I much rather have the company spend way less money just replacing motors then a lot of money on a whole new assembly which may or may not be a referb.
