signalflow
After 2 GSSL's I thought I would try my hand at these. I've already used them in the studio and the amount of detail I got was unlike anything I've ever gotten before, clean, clean, clean. I've never had such and easy mix. I used them on everything, so i could get a feel for what I had. As soon as the client puts up a link on his website I'll post it here.
Ok, here are some shots.....
Inside before pre-amps were mounted. The PCB on the back panels is an un-named firewire A/D board that at this point is still not working right....oh well, that hurdles next.
Pre's mounted and cabling ready for front panel. since the boards were lined up perfectly I used lines directly through the power and ground terminals in groups of four to send power instead of doing jumpers with molex connectors on each one, pretty much the same way older consoles do it I think.
Here is the back/front panel with switches, gain and power mounted and ready for the front/front piece. This was actually out of necessity and not creativity(well creativity after the point :wink: ). I totally screwed up the front panel when i tried to drill it myself :roll: oh well live and learn.
And here is the final product in the studio with my first two builds, nothing special about those but the third one will have the turbo and possibly the crush & blend in the unit.
Thanks to all that helped answer questions knowingly or not. Keith this thing is amazing thank you for your time designing something fantastic!
Gustav thanks for the boards, I'm sure the bug will hit to build more of these.
-Casey
-Casey
