Tekay
Hi!
Been thinking for a long time to use Traco's dc/dc converters to get 48 volt from 24 volt supply. As +/-15 volt is the highest voltage = 30V between + and - and since Tracos concerters input are totaly isolated from the output uyou can add these 30V to the incoming 24V = 54V.
So I connected the minus output (-15V) to the incoming +24v then you'll have 54V between incoming ground and the + 15V out. Just added a 220uF / 100V.
Tracos smallest converter is good for 35 mA. This will probably work with other brands too!
You'll find a schematic here!
http://www.vintagedesign.halmstad.net/diy/schem_mods.htm
