rodabod said:
This has been discussed a lot over at R/E/P.
I don't really know what to think since I don't have experience with using an original U47. I'm guessing the EF86 and Nuvistor follow-ups were thought to be crummy because the plate impedance was probably too high for the original BV8 transformer for a kick off.
Dale has mentioned here before why the original U47 circuit was quite a neat design which is probably worth researching.
As for a general answer though, my opinion on most recording gear which has a distinctive sound, often I find it has to do with the distortion characteristics, whether adding harmonics, or softening the overall timbre of a sound.
There are endless unverified (and unverifiable) myths and legends about this tube. As all the people who designed and used it are no longer with us all this must be considered as pure speculation, at best... We should leave the pure subjective domain and try a more scientific/technical approach. No "Black Art" here (only a black tube!) , after all this is only an old triode-connected RF pentode in a metal bulb. His rarity and very high price doesn't necessarily means it can't be substituted. I doubt NEUMANN enginners then spent thousands of hours in comparative subjective listening tests,nor did they had thousands of different tube types to choose from. Selection of the VF14 was done strictly on technical engineering considerations and tube availability. These are my own (unverifiable) speculations to be added to the story: choosing the
VF version was only a consequence of power supply implementation:low noise/ripple heater DC supplies were not easy to make then and it was much simpler to use the 55V/50mA heater version: all you needed was an extra dropping resistor from the already available well filtered B+ plate voltage.(and one less connecting wire !) A good and logical engineering trick then... when the VF14 was widely available ! Again, no Black Art here. Apart the heater ratings,an
EF14 has exactly the same electrical spec's and there is no reasons why he should "sound different" ,if correctly implemented. None of these tubes were "specially designed for microphone use", the
VF14 was simply "selected" for low noise and grid current and then re-labelled
VF14M (like the earliest
RE084K MIK used in the CMV Bottle).
ANY tube can be selected for low noise/microphony/grid current. I once opened (actually,sawed) a defective VF14 and found nothing "magical or esoteric" inside,only a rather crude old radio pentode typical of that era. It's not the tube but the way it is used in the
U47 which is special: as you probably know it is quite under-heated and this has considerable effects on the electrical characteristics of the tube. (see other thread about lowering tube filament voltages), this was a deliberate technical choice by the
NEUMANN engineers, another well know trick then,also called "heater starved mode".
Does ANY "VF14 Experts" ever took the time to actually trace the curves of a triode-connected VF14 at reduced filament voltage,exactly as used in the U47 ? It would be the first thing to do for any serious analysis purposes. So far, I've never seen this information. Of course, a
EF14 used @ 6.3V will have different electrical spec's and will "sound different" ! At reduced filament voltage (and same cathode t°) it will be indistinguishable from his (50 times more expensive) VF brother. Due to their peculiar heater scheme there are unfortunately no know "plug and play" substitutes for the VF14 in the U47. With some changes in the power supply/wiring/cathode bias resistor there are LOTS of possible (cheap) substitutes : all you need is a triode (or triode-connected pentode) with the same electrical characteristics/curves as the under-heated ("starved") VF14,low grid current/leakage and low noise/microphony. Such a tube is not impossible to find, but stay away from 13CW4 nuvistors ! (probably the worst VF14 substitution ever !) The U47 is still a wonderful-sounding mic with a good VF14 (and capsule!) I wouldn't touch it. Unfortunately,vintage genuine VF14's in good condition are extinct and will never be reproduced. (Sorry, TFKUSA !) At some point a substitution will need to be considered to preserve these mic's and it's time to break the myth that this tube has some "undiscovered/inexplicable magical properties" and can not be substituted without loosing all the U47 outstanding qualities. Nothing is farther from the truth.
