Same Gates thread, I posted all the SA-70 variants. I'm not real thrilled with the Gates circuit you found. You need some other input, anything used by anyone in any NYDave build will work. Buy expensive, buy cheap, manufacturer of your choice (other than Edcor). Original iron would be great, but if you went looking you'd hunt for a long long time. I have some appropriate non-exact vintage iron languishing in the black market, but that's another story. The type of circuit is the key to what you are after, and any iron that suits your taste will do the job. No one builds zero feedback preamps now because absolutely everything has to be right. And, there's no such thing as day to day repeatability in manufacturing; it's a very organic beast. You can't build a mass produced product line on these sorts of tolerances these days. The (good) old stuff built without NFB loops used the absolute best and most expensive parts one could buy at the time, and those circuits generally haven't been produced since WWII and before. Again, can't build a product line with that mindset today. The BA-2 is a hold-out in 1950, and the 6Q-1 is a real oddity for 1956 when it went out of production. The early Sun Records sound went through an RCA 76 series console that was purchased second hand, and used a preamp circuit that dated to 1939. I'm not sure modern tubes are up to the task, and you definitely can't build a product line on vintage stock. Not without tolerating the risk of unavailability. You can build some for yourself, and get enough tubes to select clean and quiet sounding examples, and I think it's worth the effort. NFB loops even out the majority of noise and gain differences between tubes. You can stick any working tube in and get pretty much the same result, aside from hair-splitting gearslutz/audiophile observations. You build without NFB, and you need to select quiet parts and tubes if working with quiet sources. If Little Richard shows up, it don't matter!
