tamas,
i read in a neumann publication from the 60's that after having done research on xformer and xformerless o/p topologies, they decided to go with xformers for their main series because if allowed for the least current draw while taking up about an equal amount of space. but maybe noise was an issue, too.
they did use the xformerless topology in their km7x series, but aside from being a/b-powered, these obviously were made mainly for mobile recording. o/p level was higher than the xformer types, maybe even close to line level, and probably able to drive e.g. a tape deck (=> nagra) without any extra pre.
clearly, there obviously are/were a lot of design philosophies regarding o/p trannies. some mic's use an emitter follower after the fet's drain, others use a source follower before the emitter follower (e.g. the old akg c414's) for even lower Z, again others (e.g. new 414's and u89) use more amp stages that bring the o/p Z down so low that it seems likely they use a 1:1 ratio.
