user 40373
- Joined
- Nov 22, 2009
- Messages
- 109
I need to order some .1uF mono ceramic capacitors but there are so many, I don't know what to get. These are being used for HF suppression.
abbey road d enfer said:Where? Can you post the circuit diagram?
X5R is better than X7R.
jdbakker said:0.1u/100n is pretty large for an HF bypass cap; almost all capacitors you'll find in that value have a rather low self-resonance point (ie: the point where they stop acting like capacitors and start acting like inductors).
I'm curious about JDB's comment also. Most bypass caps (on PSU boards as well as audio boards, close to opamp V+/- pins, etc) I've seen in projects around here are 0.1uF (100n) and no one's ever mentioned the low self resonance point before. Would .01 be better?sws2h said:jdbakker said:0.1u/100n is pretty large for an HF bypass cap; almost all capacitors you'll find in that value have a rather low self-resonance point (ie: the point where they stop acting like capacitors and start acting like inductors).
So, some 6 cent Vishay X7R ceramics will be ok for bypass caps? Should I stick with the original value of .01uF instead?
You need only 15V!sws2h said:X5R only goes to 50V and are not available in .1uF, at least from mouser. I need through-hole.
Me too, curious. A 100nF ceramic has its typical minimum impedance at 3-8MHz, as compared to a 10nF, which is at 10-20MHz. If you're concerned about RFI, smaller caps may be more effective than larger ones in a particular bandwidth. The choice of smaller caps may be done according to the environment (like a 20MHz clock), but I think that, for a unit that does not have digital signals in, larger caps are preferrable. And anyway, any less-than-perfect PCB routing decision can ruin the theory.mitsos said:I'm curious about JDB's comment also. Most bypass caps (on PSU boards as well as audio boards, close to opamp V+/- pins, etc) I've seen in projects around here are 0.1uF (100n) and no one's ever mentioned the low self resonance point before. Would .01 be better?
abbey road d enfer said:mitsos said:I'm curious about JDB's comment also. Most bypass caps (on PSU boards as well as audio boards, close to opamp V+/- pins, etc) I've seen in projects around here are 0.1uF (100n) and no one's ever mentioned the low self resonance point before. Would .01 be better?
