NewYorkDave
Nothing fancy... Just two fixed-gain feedback amplifiers with a volume control.
Schematic(48kB GIF)
I needed 50dB of gain makeup for my passive mixer design, and this is what I came up with.
The THD figure at max output is a simple estimate based on THD readings I took of the two amplifier stages separately. It's just a summed figure, and the THD of the signal generator was not subtracted. Since some of the distortion is noncoherent, and thus does not simply add, actual THD should be a bit lower. I haven't had a chance to test the entire circuit as "one piece" yet.
Schematic(48kB GIF)
