So it is - my mistake. no issues there (I just cant read).
Haha, no worries
Can you tell me more about the cnb. Obviously there are the traces to cut on the pcb also. I am just curious i guess.
The CnB provisions are for using an external CnB board, however it has not been tested, but in theory it should work fine.
DO NOT cut those traces unless you're hooking up an external CnB board though, otherwise your unit will not work.
Not that i am ready, but is there calibration process document in the works?
I'll post the quick and dirty instructions here the next day or 2. I've fallen way behind with things due to my surgery. If anybody gets to that point, let me know and I'll walk you through it, it's easy.
Also the assembly document has non existent links on page 4 for the enclosure. only has 'www.' on the version i downloaded to look at (unless it has since been updated).
Again, will get it updated soon. They're just dimensions on where I mounted my boards. No need to even follow what I did though, you can mount them whatever looks good.
