saxtim
I've completed a DIY version of the U87ai, schematic here:
http://www.omnipressor.com/MicSchLib/u87ai.gif
I'm using a cinemag 10.5:1 microphone output transformer (David Green recommended the model, not on the website - it's designed as a mic output and is humbucking. Nice and small, which made packing the circuit into a Nady SCM900 body much easier)
I wound my own auto-transformer and I'm generating required +/- voltages from the DC-DC board (see http://www.groupdiy.com/index.php?topic=1651)
Anyway, I'm getting some output though it's extremely low. For example I put my preamp up to close to full and more or less yelled into the mic from 5-6 inches and it only justs registers a signal. When recorded you can hardly hear it - sorry, I deleted the file before noting down actual level measurments. Either way though, it's way too low to be functioning correctly. As a side note, there doesn't appear to be any noise (hum, hiss etc), so that's something at least.
At first I thought I had wired up the transformer incorrectly, but swapping the transformer round the other way yielded no output at all.
I've biased the FET and it's giving somewhere between 10-11 volts, depending on what phantom supply I'm hooking it up to. It's biased with an 11K resistor to get this voltage. I'm using a 2n3819 FET. I remember a thread a while ago (going back several months) where Gus mentioned building a circuit with this Fet and finding that very few biased well for mic use. I'm not sure if that's the problem, but perhaps a consideration?
Low cut and -10b pad are working fine (best I can tell from extremely low output).
I'm using a cardiod only chinese capsule, so I haven't tested the pattern switch yet.
Suggestions?
thanks
tim
Suggestions?
thanks
tim
