TobWen
Hi there,
I am looking for a parametic EQ.
I'd like to set Q-level (bandwith) on my own.
The EQ should have some "grip" (I don't know what's the correct translation, but you should feel, what it is doing!).
On this board, I found these ones:
CAPS EQ (http://users.pandora.be/Rogy/IEMFinalizer/CAPS EQ)
Net EQ (http://www.wavefront.mcmail.com/neteq.pdf)
I don't know anything about them ... can anybody help me?
I've already found these things:
1. Symetrix 551E Five Band Parametric EQ
http://www.symetrixaudio.com/tech_support/schematics/55xE-1A00.pdf
2. RANE PE17
http://www.rane.com/pdf/pe17sch.pdf
Funny, seems like Symetrix & Rane did some teamwork :grin:
3. Behringer ULTRA-Q PRO PEQ2200
... no schematics here ...
Okay, the Behringer seems interesting ... 54 EUR only.
BUT: Pro-Series, SMD and 4560/4580 OPAs :-(
What do you suggest?
Tobias
Low Cut: 6 - 260 Hz
High Cut: 3000 - 65000 Hz
Frequency: 100 - 2000 Hz (x0.1, x10, x1)
Bandwith: 0.05 - 2.0 Octaves
Level: -20 - +12 dB
2. RANE PE17
Low Cut: 10 - 250 Hz
High Cut: 3000 - 40000 Hz
Bandwith: 0.03 - 2.0 Octaves
Level: -15 - +12 dB
Low Cut: 10 - 400 Hz
High Cut: 2500 - 30000 Hz
Frequncy: 20 - 400 Hz
Bandwith: 0.03 - 2 Octaves
Level: -15 - +15 dB
Frequency: 60 - 1000 Hz
Level: -15 - +15 dB
Frequency: 150 - 2500 Hz
Level: -15 - +15 dB
Frequency: 500 - 8000 Hz
Level: -15 - +15 dB
Frequency: 1000 - 20000 Hz
Level: -15 - +15 dB
Tobias
