Status: Finished*
I've been reformating the SSL9k BOM,
since I found the Neeno pdf machine-unreadable.
Please refer to the original bom found Here
The reformated BOM is Here
To do:
PSU BOM if anyone wants to do that
My aim for the BOM is budget-, newbie- and Europe-friendly and with good quality. I see no reason it shouldn't fit well for world-wide either, especially if you look at some choices I've noted.
Farnell is my main supplier for this BOM, adding a couple of more when Farnell can't supply or is to expensive.
Please:
- Check for errors
- Add useful info
..this a little experiment, to see if this is helpful for many, if it can be done like a colleboration, and if Google docs is a good place to do do this. Have fun!
I've set the settings so everyone can read and edit,
but I might change that for editing if it becomes a problem.
*Disclaimer: I've done my best to make sure this BOM with parts are correct. But, I'm one of the least qualified and experienced persons here. So, before some pro-guy states the parts are correct and a good choice, you should check things for yourself.
To do:
Please:
- Check for errors
- Add useful info
