> that parallel resistor method looks just fine !
No.
No.
No.
No.
No.
> calculation for the Calrec EQ freq pot C100k.
I don't know this specific box. But nearly ALL frequency dials attached to resistors obey a law like F = 1/RC. Bigger R, lower frequency.
And we usually want frequency on "Octave spacing". We need to cover 1,000:1 of frequency, and while we might want 1Hz resolution at 20Hz, we sure don't want 1Hz resolution at 20KHz.
So take a straight 100K pot. Assume you pick C so that it works at 100Hz. Then the resistor value versus frequency looks like:
100K = 100Hz
90K = 111Hz
50K = 200Hz
20K= 500Hz
10K = 1KHz
zero = infinity
The octave from 100hz to 200 Hz fills half the dial. The four+ octaves from 200Hz to 1KHz are crammed into "5" to "1" on a 0-10 dial. The pretty important octave 500Hz-1KHz is crammed into "2" to 1", whereas the "10" to "9" range covers only two semitones.
Your proposed pot is worse. At "1" it isn't 10K like straight linear, it is 55K. The octave from 500Hz to 1Khz is, I think, crammed into "0" to "0.24", on a 1-10 dial.
If you want to cover a 10:1 range, nicely, you want "5" to be about 0.316 instead of 0.5; to cover a 25:1 range you want "5" to be about 0.2.
And you can't get there by slugging a reostat.
