fznuk
Member
Hi Guys,
Im new to the forum...so a big hi from Wales. UK!
I stumbled across this great informative forum when my Behringer ADA8000 died on me this morning after years of use
And, as with most Behringer kit..its the poor PSU's - or so it seems with this kit! (I also have a DDX Behringer mixer that needs repairing...and yep, the PSU!!)
My ADA8000, on closer inspection, had blown the rear fuse (T3.15A) which i replaced...the unit fired up ok but i heard a crackling from the transformer which started to heat up rapidly...so before it burnt out i read on here a regulator could be shorted, raising the current draw and might be why its overheating?
I done a bit of reading on here and concluded that it might be a great idea to rebuild an external seperate PSU but would just like a few things clarified if possible?
1) What are the pin-out voltages of the transformer?
2) What are the current ratings of those voltages?
3) does it need to be a toroidal transformer? Can i use switch-modes? I have a mass collection of different PSU's, transformer and SMPT's.
4) Is it still best to add the bigger CAP's and Resistors?
Cheers guys!
Cheers guys!
