Author Topic: Square holes in printed circuit boards?  (Read 575 times)
zebra50
  • Member
  • York, UK
    • http://www.xaudia.com
« on: June 08, 2012, 05:09:16 PM »
Hi!
I have seen a couple of circuit boards around with square holes for transformers and other components to sit in / pass through. Like this, for example....
Does anyone know which programmes / manufacturers support boards with square / rectangular holes? Preferably on a mac!
I tried to design a board using Fritz, which is very easy to use, but does not support square holes.
Many thanks
Stewart
Ribbon microphone services
Microphone blog
zayance
  • Member
  • France/Swiss
Re: Square holes in printed circuit boards?
« Reply #1 on: June 08, 2012, 07:50:05 PM »
This can be done in the Milling layer on PCB softwars, Eagle has this layer for example, and the idea is to draw the rectangle with the correct size where you want it and that's that.
I think it can even be done in the Dimension Layer (wich is normally the one used for the contour of the board).
Not aware of Fritz tough....
buildafriend
  • Member
  • Brooklyn, NY
« Reply #2 on: June 08, 2012, 09:44:53 PM »
why do you want square pads for anything but to indicate polarity?
the way we question things defines who we are
PRR
  • Member
  • Maine USA
« Reply #3 on: June 08, 2012, 10:07:57 PM »
Holes. Not pads.
zebra50
  • Member
  • York, UK
« Reply #4 on: June 09, 2012, 02:12:43 AM »
Thanks Tony! I think I have to find someone with Eagle. I don't think Fritzing has a milling layer, which is a shame because it is free, and very easy to use.
http://fritzing.org/
Holes. Not pads.
Yes, I want holes for the magnetic components - like where it says 'T1' on the board, only smaller in my case.
Thanks again for the suggestions.
Microphone blog
zayance
  • Member
  • France/Swiss
« Reply #5 on: June 09, 2012, 04:18:49 AM »
Maybe i can help you out? Let me know.
T.
zebra50
  • Member
  • York, UK
« Reply #6 on: June 09, 2012, 04:55:44 AM »
Thanks Tony - maybe you can! I will send you an email.
Stewart
Microphone blog
peterc
  • Member
  • Johannesburg, South Africa
    • http://1176neve.tripod.com
« Reply #7 on: June 09, 2012, 07:14:54 AM »
Stewart
For the 5003 PCBs, I made a note of the hole sizes, and the plant did the necessary coding for me.
On the PCB design I put in a cross-hatched area, and said "Hole size: Xmm x Ymm"
Worked fine.
Peter
Real men do it single-sided
