t-wurst
Need some help please guiding me in the right direction.
Problem:
I wired and fired up 2 of those nice SSL.
One board came out a bit dirty due to a crappy solder tip and i forgot to wipe off the photostuff with aceton.
The other board looks pretty good. Everything is shiny, got a brandnew tip, measured every resistor before it´s soldered (except of the MegaOhms cause my DMM is too small (!) - uh, maybe there´s the fault?! )
I have all the right voltages +/- 15 +/- 12, the XLR´s are grounded, the unit passes audio. dbx in right direction (used verbos´). I have bridged the Makeup/Bypass conn. on the control board with a jumper because i still miss the switches. (both bypass joints and the com/on joints) Meter works like it should, threshold drives the meter different, meter follows signal.
BUT
Makeup doesn´t work, there is no audible compression and in my opinion, the voltage regulators getting too hot. It takes maybe one or two minutes, then u can´t touch them much longer than a few seconds. Maybe this is normal, i used 2x18V torroid? So i switch it off after 1 minute and don´t have much time for measurements..
Voltages vary on 074 pin 7, somewhere between +0,15 and -1,9 Volts, i measured 072 pin 8 i think, but there are not the voltages inverted like Jakob suggested.
Both channels passes audio clean and without distortion. But theres no audible difference when compression is ON
The same behavior with the other control board.
Today i spend a few hours for tracing the board for solderblobs, shorts, cold joints eg. Nothing. Everything seems fine. BUT NO COMPRESSION
Someone mentioned that he put a 3M9 instead of an 3K9 in control board. Replacing it with the RIGHT 3K9 so it works. But the layout PDF says 3M9.
Which one is the correct? And how hot could the regulators get??
Any hints? Thanks in advance
toby
Problem:
BUT
toby
