A nice collection of DIY!
Just a few thoughts on getting the hum lower...
Have you wired the output transformer as 1:2? This naturally brings the noisefloor up +6dB. I found that wiring a strap of thick wire diagonally across the board from the 0V input point to the ground point across the board helped a bit (unless this is one of mnats boards, where I think he broke the loop with a bit of reworking of the ground traces...)
Also, is the power switch on the front panel switching the mains supply? From the pic it looks like the mains leads pass directly over the top of one channel- and near to the "link" wires (which are high impedance paths and should be well screened to prevent modulating the gate of the FET with external signals!) Check and double check all your screens and cabling. Use "sliding shields" where you only connect one end of a screen to 0V, and arrange multiple screens (e.g. the path from main board, to a pot, and back again) with the screens linked in the middle but only at one end.
Great DIY work though!
Mark
