electronaut
Hello,
A friend has had these preamp modules lying around for years and hasn't been able to use them because they don't have a power supply. He's a fantastic engineer, so I thought I'd build him the supply so he could keep recording music that I like.
Here they are:
And... (Promise to keep CJ away!!)
Transformer
Here are the insides:
Insides
From what I can gather, Northern Electric was Canada's branch of Western Electric. These modules are apparently out of some old console, but I can't find any information about them anywhere. The module is #R6409A. Does anyone have any clue as to where these came from?
Better yet, does anyone have a schematic?
I've been staring at these things for a while now and have managed to figure out the following:
I can't yet guarantee it's perfect, but I checked it a couple of times and I'm pretty sure it's right.
I haven't figured out the input transformer yet.
There is a component in there that I do not recognize, and before I desolder it and play around with it, I figured I'd ask if anyone here knew what it was. It's a trimmer of some sort, but it's not labeled on the chassis. It appears to be in the (first) feedback loop, and it's the question-mark in the schematic. In the photo it's the white thing in the center:
weird part
And what's with having TWO feedback loops? I've never seen that before.
Another weird thing is the heater wiring. Only half the 12AX7 is used. (Pins 1, 2, and 3 are grounded). So they only bothered to heat the other triode, using 6 volts from pin 5 to 9. This surprised me, not only because I hadn't seen it done, but also because I would have thought the inside temperature of the glass envelope would be dependent on having both heaters powered, and that conduction would suffer with less heat.
It's a bit tricky to figure out exactly what's going on because all external connections are made through an 18 pin Amphenol connector, and obviously I don't know what they're connected to.
One of the coolest things is the input potentiometer, which is also a switch that opens when the pot is fully clockwise. It seems the input can be switched to line level once the switch is open, since the pot becomes a series resistor with no reference to ground.
If anyone has any comments, suggestions, etc. I'd love to hear them. What voltage do you think I should make the B+?
E.
Here they are:
Transformer
Insides
weird part
E.
