kkrafs
Hi folks!
I green in tube design (but im learning slowly),
have some questions.
Have there been a variable Mu tube compressor design
where the peak limiting rectifier sensed the signal "before"
the compressor stage instead of after?
Have anyone any experience of the 6L7GT sovtek tubes
in a variable Mu application?
This might be a corny qestion but what is the crosstalk
figure in a dual triode? Between the two triodes that is?
Im curious to know!
Some tube compressors feed the peak limiting signal trough two
resistors into each grid, e.g, UA175,Altec 438A, and others feed the
signal throug the resistors and the center winding of the input tranny,
e.g, BA6A, Altec 444. What are they tryng to achive by doing either
way?
Most classics are old designs but wich one is the most modern in
respect to engineering?
And wich compressors are the most classic and regarded,
in its field of usage? Im trying to learn wich one is used in wich situation.
Reg
KKRAFS
Im curious to know!
way?
Reg
KKRAFS
