Finally, some feedback! :thumb: Excellent comments, guys! I do not have the kind of perspective or experience to pick up on these things. Allow me to address:
[quote author="bcarso"]Your 317 won't be happy short-circuited, but you will always have those 6.81k R's going to the outside world except during construction and test, presumably.[/quote]
What is the secondary voltage of the Amveco you mention?
Its supposed to have two 12V secondaries, which I've wired in series for 24V. I was surprised to get as much as I did but 31V was nominal after construction. Same thing happened with a couple of other 115V:12V trafos.
Of course the ripple you measure with the DMM is without load on the input to the 24V reg (?), and I am not sure what the Neve draws or for that matter how good its power supply rejection is.
Yeah, unloaded. I believe they draw 120mA max per channel, plus an LED = 260mA. I've measured about 65mA per channel with no i/o connected and the bias trim for the 3055 turned down lower than usual. For the 48V supply, total draw is <70mA.
(2) Anytime I see a wiper I conjecture what happens when that wiper becomes open or intermittent.
Good point. I didn't think of this. The tolerance and reliability of the Bourns trimmers I was using was sufficient, but better play it safe (and save $3!). Fixed resistors it is!
Again, whether the power supply ripple/noise rejection of the Neve modules is sufficient to allow the use of the relatively noisy 24V regulator is something I can't speak to. Also, I don't know if the Neve modules have local filtering as well, which would make the regulator noise less of an issue.
So you're saying the 7824 is noisier than the 317? I wasn't aware of this. Funny, my original design used two 317s but I wanted to reduce the number of components. The 24V is applied to the modules through single stage RC filters and so is the phantom, but I'd rather have redundancy and a sharper slope. Again, I originally had some hefty RC filtering on both outputs, but wanted to reduce heat, cost, and number of components. Oh well, no free lunch!
You could increase the output cap on the 24V regulator for better transient response I think.
Couldn't figure out the formula for this so I just used the recommended value from the application notes.
That was a nice lesson for me. Thanks a lot, Brad! :guinness:
