tmbg
Ok, so I'm restarting this thread over here, with new and exciting info.
I'm working on putting up a little site for these guys, which is printed on the back of them, and I'll have the schemo and pictures and stuff up there.
Here's the pics of them for those of you that missed the first go round:
Also, here's a simple sound clip for ya - it was recorded very straightforward, with an SM-58 straight into ADA8K, into hammerfall 9652, into Nuendo. It's recorded at a level where the version with the ARP in wouldn't clip, which makes the non-ARP version a bit quiet because of the gain the ARP has. It's me playing the guitar with the mic about 3-4" from the neck joint of the guitar. Please be gentle, I am NOT a guitar player
I used an SM-58, and not a ribbon, because another ARP is installed in the ribbon, and I didn't want to take it out to give you an A/B. Sometime soon I'll get you a clip of the improved fum ribbon, but I want a decent source to put in it first!
http://diy.usedforcomparison.com/arp/media/arp-clip.wav
One of the boards I have is bad. That leaves me with three assembled ARPs, one is installed in my mic, I have two more, and I'd be happy to sell them to a couple of early adopters, which will help me finance the prototype of revision 2, and a production run of both.
revision 1 doesn't have a good mounting solution for the ribbon, but it is perfectly fine for using as an in-line preamp for any mic that's not already phantom powered. Obviously you can't put this in front of a phantom powered mic without adding another phantom power source on its input, because the ARP eats the phantom on the line. Revision 2 is designed to replace the scrap of PCB that lives inside the fum ribbon, has the same mounting holes, and has enough throughholes to make the off-board connections, four holes for the ribbon wires, four for the transformer, four for the XLR jack (quad cable), and all the components on board. The caps are throughhole, and located toward the edge of the board, and the rest of the components are SMD, as the board mounts right on a piece of metal that precludes throughhole components in the center of the board.
I'm toying with the idea of a box with just a 48V PSU, and interconnects with the 6k8 resistors built in, so that you can chain together 5 or 6 of these guys to make a mic preamp. Might be stupid, might be really cool
So guys, first couple people to pm me about the prototypes can buy 'em, and everyone let me know if you're interested in this, and which type of board you'd like. I'll probably do a production run of both types of board, so I want to get an idea how much demand there is for each.
