I have to put my hand out for some unashamed spoon feeding, my learning curve on this is brutal, I know this must be simple for someone out there-
I have a few things Im racking right now and instead of using the standard -20dB pad I think I'd like to try a balanced input attenuator before the mic input transformer.
I'd like to build a suitable series attenuator to do 4 dB steps down to -20dB into 150 ohms.
Im trying not to get too spendy right now, I looked at the alpha switches available from mouser and cant at all understand how the F they have them categorized, which shorting switch will work for what I want? I want to do a six position switch, 5 pad sections and one bypassed.
This seems like a standard thing we could probably all use on any mic preamp with a 150 ohm input transformer, right? Might be good to store this in a meta somewhere. There could be a racking meta, everything you need to rack a box, links to pahntom powering, swithcing, this kind of stuff.
thanks in advance!
dave
thanks in advance!
dave
