SSLtech
Hi all.
I have to build a preamp for a specific application. It's a matched-gain 4-channel preamp to take an unbalanced, "higher-than mic-level-but-not-quite-line-level" signal from a soundfield mic (ST250) and make it go (balanced out) straight into a multi-channel recorder.
The output of the ST250 has +25V on the outputs (an anomaly of its design) and so there are blocking caps at the input, not shown.
I have built the last 2/3rds of this design (basically everything from R5 onwards) and it works well and tracks to a fraction of a dB, using a 4-channel pot which I found to do the job.
My problem is that the ST250 overloads rather easily when it gets close to a brass band if they happen to be playing at anything like full chatter, or in a 'loud' room. If I switch in the "attenuate" button, then the gain range of my currently built unit is not high enough (it currently ranges about ±11dB) to use the full bit range of the recorder, so I want to build a matched but variable gain stage ahead of the exicsting stage.
With the current unit (the last 2/3rds of the schematic pictured below) noise is not a problem (not since I de-mounted the regulated power supply) and I tried 5532s and 072s and measured THD and noise on both chips. In some gain settings, there was not much to call between them, but at one setting, the 072 showed almost 10dB lower noise, so I went with the 072s.
This is a 4-channel design, here is one channel shown:
Subtleties like local decoupling and inter-stage DC-blocking caps are not shown, for clarity.
The gain error between channels absolutely must be kept minimal at all times, and using a 4-gang pot, the inevitable mechanical resolution errors mean that the more gain you "put around" that section, the more inter-channel tracking error you can expect. I can't afford that, since this is for a "B-format" SoundField application, so a seperate, switched +10dB and +20dB section would be perfect, since 1% or better metal film resistors will match much better.
Can anyone see any great flaws with this approach? -I need it to be buildable quickly, easily and using what I have or can get promptly. -I have a few 4-gang double-throw switches, so if this is a reasonable idea I'll go right ahead with it.
I'm not a great designer, and I respect the ideas and noise theory knowledge (of which I have a woefully inadequate grasp) of folks like PRR and bcarso, so I though I'd post it to let everyone here treat it like a pinata for a while! :wink:
Thanks for lookin'
Keef
Thanks for lookin'
Keef
