Svart
some who have been following the Chimera PCB buildups(in the Blackmarket) by myself and a few others will recognize the problem I am having..
I am running the quad preamp with 2 Lundahl LL1538xls and 2 31267s on inputs. the channels with the lundahl trafos are clean, quiet and very nice.. the channels with the 31267s are terribly noisy(hissy) and have large amounts of 60 and 120hz hum. Hooking any mic up to it actually makes the noise worse by another 20% or so even though audio can clearly be heard through the hum and hiss.
I wired the 31267s backwards as JLMAudio proposed on the website. I tracked the issue down to the input trafos and removed the + output of the trafo to the board. the channels are now super quiet like the others so it's clear that something is not working together here.
I noticed that my Lundahls have a static resistance of ~120R inputs and ~800R output. the 31267 has ~60R input and ~150R output..
I grounded the case of the 31267 which actually made things worse for the time being. I then fooled around with different wirings and found that series wiring for both sides is the quietest, almost identical to the other channels. removing the grounding now makes things worse.. go figure..
I assume the impedence is incorrect somehow and that some kind of termination/zobel is needed to use the trafo as a direct replacement for a 10468?
any ideas?
thanks! :thumb:
(edit) I also haven't passed audio through the channels that have been rewired since I changed them..
any ideas?
thanks! :thumb:
